Published Articles
Articles by BSC employees published in professional and trade magazines.
ECM Efficiency—Better (and Worse) Than You Think
- Electrically commutated motors (ECM) in air-handler fans promise improved efficiency. But does improved technology necessarily mean efficient HVAC systems? This article was first published in Home Energy, May/June 2010. Reprinted with permission.
Future of Framing is Here
- Smarter strategies can save money, speed construction, improve energy efficiency, and cut down on jobsite waste. Reprinted with permission from Fine Homebuilding, October/November 2005, pages 50-55.
Moisture, Building Enclosures, and Mold
- How water gets into a structure, why it doesn’t leave, and how these architectural flaws become HVAC headaches. This two-part article was first published in HPAC Engineering, December 2001 and January 2002.
Mold Explosion: Why Now?
- Today’s houses make it easier for mold to find the food and water it needs to thrive. The cure is a quick cleanup and smarter choices in materials. Reprinted with permission from Fine Homebuilding, December 2006/January 2007, pages 70-75.
Remodeling for Energy Efficiency
- Can a 150-year-old house approach zero energy use? Three case studies point the was from the 19th to the 21st century. Reprinted with permission from Fine Homebuilding, April/May 2008, pages 51-57.
Small House, Built Right
- Think $50 per square foot and $50 a month for utilities are unattainable? Government-sponsored research proves otherwise. Reprinted with permission from Fine Homebuilding, June/July 2005, pages 56-61.
Water-Managed Wall Systems
- Show water to the exit with a well-detailed drainage plane and flashings. Rerpinted from Journal of Light Construction, March 2003.
Residential Ventilation and Latent Loads
- Outdoor air is added to a building via a controlled ventilation system. What isn't controlled is the air change created by wind effects, stack effects and pressure effects caused by the operation of the HVAC system. The following article was published in ASHRAE Journal, April, 2002, pages 18-21. Reprinted with permission.
Built Wrong from the Start
- Top ten blunders that rot your house, waste your money, and make you sick. Reprinted with permission from Fine Homebuilding Magazine, April/May 2004, pages 52-56.
The Future of Window Technology . . . Is Here!
- Windows and curtainwalls are ubiquitous building enclosure components. Like all parts of the building enclosure, they have to meet the fundamental functional requirements of support, control and finish (Straube & Burnett, 2005). Reprinted with permission from Journal of Building Enclosure Design, Winter 2010, pages 12 -15.
Adhered Veneers and Inward Vapor Drives: Significance, Problems and Solutions
- Adhered veneers, in which masonry units are directly attached to a substrate via mortar and ties without a drainage or ventilation gap, have become a very popular finish in residential and light commercial construction. Reprinted with permission from Journal of Building Enclosure Design, Summer 2009, pages 31 - 35.
Measuring the Impact of Interior Insulation on Solid Masonry Walls in a Cold Climate
- Evaluating the risks associated with insulating exterior masonry walls from the interior on a three-story school constructed in Toronto, Ontario in the late 1950s. Reprinted with permission from Journal of Building Enclosure Design from Summer 2009, pages 11 - 17.
Public Housing Breaks the Mold: Part I
- Multifamily public and low-income housing have particular problems when it comes to moisture and air pollutants. In this first of a two-part series, we look at one particular type of multifamily construction: midrise housing. Originally published in Home Energy September/October 2001, pages 24-28.
Public Housing Breaks the Mold: Part II
- Here we explore issues unique to Veterans Era Housing and present three cases where moisture problems were successfully addressed. Originally published in Home Energy November/December 2001, pages 33-37.
A Crash Course in Roof Venting
- Understand when to vent your roof and when not to, and how to execute each approach successfully. Reprinted with permission from Fine Homebuilding, Aug/Sept 2011, pages 68-72.
Throw-away buildings: The slow-motion failure of Toronto's glass condos
- Over the past decade, Toronto's building boom has been dominated by tall glass condo towers.
Foam Shrinks, and Other Lessons
- What we learned from updating a 16-year-old deep-energy retrofit. Reprinted with permission from Fine Homebuilding, February/March 2012, pages 55-59.
Field Performance of Unvented Cathedralized (UC) Attics in the USA
- This article reports on field experience of unvented cathedralized (UC) attics in several environments in the United States. Traditionally, in some regions of the country, because of high water tables or the risk of flash flooding and lower cost, slab on grade construction is a preferred mode of construction. Mechanical equipment for air conditioning and distribution ducts are usually located in the attic spaces to conserve space. Conventional construction involves providing insulation on the floor of the attic and venting the attic space to the outside. The loss in efficiency in operation of the equipment and through duct leakage is no longer sustainable. Insulating the attic roof itself and blocking of ventilation to the outside transfers the air and thermal energy controls from the boundary with the living space to the plane of the roof. The air distribution systems now fall within conditioned space, which increases their efficiency, durability, and maintainability. This article was first published in the Journal of Building Physics, Vol. 29, October 2005.
Foam Shrinks Correction
A Critical Review of the Use of Double-Façades for Office Buildings in Cool Humid Climates
- So-called double-façades (DF) or ventilated façades, environmental second skins, etc. have attracted great interest as modern building enclosures. Numerous examples have been built in Europe but only a few have been completed in North America. The DF label actually covers a wide range of different enclosure types. In most cases, a DF has three layers of glazing with ventilation and solar control devices between the outer two glazing layers, although some ventilate the space between the inner glazings. In most cases, the airflow through the glazing cavity is driven by natural buoyancy (hot air rises) aided by wind pressure differences, although some systems use small fans (often driven by photovoltaics). In hybrid systems, HVAC supply or exhaust air streams are directed through a glazing cavity before connecting with the outside. Reprinted with permission from Journal of Building Enclosure Design, 2007, pages 48-53.
Air Leaks—How They Waste Energy and Rot Houses
- One-third of the energy you buy probably leaks through holes in your house. Reprinted with permission from Fine Homebuilding, pages 45-49, October/November 2012.
Eliminating Attic Vents
- By creating a path for air to move, structural vents are supposed to prevent the buildup of moisture in an attic. This article was first published in Builder Magazine, January 2006.
