Search Documents   →   Enclosures That Work   →   High R-Value Enclosure Assemblies
BSC has undertaken a study for the US DOE's Building America research program to identify and evaluate residential enclosure assemblies that cost effectively provide 50 percent improvement in thermal resistance. Details regarding water management, air management, vapor management and thermal management are described in the following sheets. Look for future wall, foundation and roof case studies.
1-29 of 29 Items
 Title   Type
Additional Content Folder
BSC Article chemical/x-mdl-rdfile High R-Value Wall Assembly: 2x6 Advanced Frame Wall Construction with Mineral Fiber Insulation Board BSC Article
BSC Article High R-Value Wall Assembly: 2x6 Advanced Frame Wall Construction BSC Article
BSC Article chemical/x-mdl-rdfile High R-Value Wall Assembly: Non-Combustible Steel Frame Wall Construction with Mineral Fiber Insulation Board BSC Article
BSC Article High R-Value Wall Assembly: Double Stud Wall Construction BSC Article
BSC Article High R-Value Wall Assembly: Truss Wall Construction BSC Article
BSC Article High R-Value Wall Assembly: SIPs Wall Construction BSC Article
BSC Article High R-Value Wall Assembly: ICF Wall Construction BSC Article
BSC Article High R-Value Wall Assembly: Spray Foam Wall Construction BSC Article
BSC Article High R-Value Wall Assembly: Flash-and-Fill Hybrid Wall Construction BSC Article
BSC Article High R-Value Wall Assembly: Double Stud with Spray Foam Wall Construction BSC Article
BSC Article High R-Value Wall Assembly: Offset Frame Wall Construction BSC Article
BSC Article High R-Value Wall Assembly: Exterior Insulation Finish Systems (EIFS) Wall Construction BSC Article
BSC Article chemical/x-molconn-Z High-R Foundation 01: Uninsulated Foundation Walls and Slab BSC Article
BSC Article High-R Foundation 02: Code-Minimum R-10 Continuous Insulation BSC Article
BSC Article High-R Foundation 03: R-13 Fiberglass Batt in a 2x4 Framed Wall BSC Article
BSC Article Troff document High-R Foundation 04: 1" XPS, 2x4 Wood Framed Wall with Fiberglass Batt BSC Article
BSC Article High-R Foundation 05: 2" XPS, 2" Foil-Faced Polyisocyanurate BSC Article
BSC Article High-R Foundation 06: 3-1/2" of 2.0 PCF Closed-Cell Spray Polyurethane Foam BSC Article
BSC Article High-R Foundation 07: 6" 0.5 PCF Open-Cell Spray Foam BSC Article
BSC Article High-R Foundation 08: 2" XPS, 2x4 Framing with Fiberglass Batt BSC Article
BSC Article High-R Foundation 09: 2" Polyisocyanurate Insulation, 2x4 Framing with Cellulose BSC Article
BSC Article High-R Foundation 10: 6" 0.5 PCF Spray Foam with 2x4 Framing Offset 2.5" from Concrete BSC Article
BSC Article High-R Foundation 11: 4" XPS Insulation on the Exterior of Foundation Wall BSC Article
BSC Article High-R Foundation 12: 4" XPS Insulation in the Center of Foundation Wall BSC Article
BSC Article High-R Foundation 13: Insulated Concrete Forms (ICF), 2" XPS on Interior and Exterior BSC Article
BSC Article Troff document High-R Foundation 14: 2" XPS, 2x6 Framing with Fiberglass Batt BSC Article
BSC Article Troff document High-R Foundation 15: 4" PIC, 2x6 Framing with Fiberglass Batt BSC Article
BSC Article High-R Wall-02: 2x6 Advanced Frame Wall Construction BSC Article
1-29 of 29 Items
